How to replace Skins on OG
Whatever doesn't doesn't fit the submission requirements, it'll be posted here.
Pruned every 60 days.
Unread postby Legion » Sun, 7th Jan 2007 23:20
For all users interested in making their own skins you can check the proper tutorial here:
tutorials.php?mode=skinning
Unread postby ErrorS » Fri, 26th Jan 2007 4:56
If you want you can also extract the texture with that program, open it in photoshop, edit it, save as a DDS and then copy the hex from that DDS and replace the old one in file.
It's a shame more people aren't into modding this game. I'm sure someone with knowhow could create a program that would do this with little effort :(
ErrorS
Unread postby Legion » Fri, 26th Jan 2007 10:09
yes, that's very, very true. I mean, even if we had to save the file as dds a program inserting the hex on the desired location shouldn't be too hard for someone with programming experience.
Unread postby Eternal_Rocker_Chick » Fri, 26th Jan 2007 17:45
Exactly, it's just finding someone with that ability. And, not everyone has photoshop, being as it's a bought product. Which results in many people not being able to change skins at their own will. I'll try and see if i an find another way to convert the files. Y'see, i had a free converter before i was using photoshop, but i lost it, unfortunantly. If i could find it again on the web, more people could be able to do the process
User Title: Talking Duck
Unread postby The Kingpin » Fri, 23rd Feb 2007 2:17
hey guys. im finally getting into skinning [watch how ERC jumps for joy behind that PC screen. i bet she's thrilled to bits that i wont be bugging her anymore :P ]. However, i have a bit of a problem understanding what the tutorial means by "make a new file with the extension DDS and open it up with the HexEditor". how do i make the new file? as in use the New button INSIDE the Hex editor supplied in the link? or make a new folder or text document? or what?
Like text RPGs? visit my site at http://www.rpgtopia.com
The Kingpin
User Title: The Kingpin of RPGTopia
Unread postby Legion » Fri, 23rd Feb 2007 10:58
create a new file -no matter the original extension- make sure it's blank and rename it to .dds, afterwards, paste the hex values into it through the hex editor.
Unread postby The Kingpin » Sun, 25th Feb 2007 15:29
ok....i've gone through the hex editor stage quite well. now onto Photoshop. i've finished the skin, but i need to know how to fix the teeth. how do i make them transparent? and is it possible to copy it out of one skin file, and paste it in another? [Crusher's teeth weren't top notch, and i thought that i'd take the CEP or Chaos Rexes' teeth and put them for Crusher...]. skinning went fine. i've done the skin almost exactly how i want it. i just need to know how to fix the teeth. TT's helping me with some of the other, smaller details, like scars...
The Kingpin
Unread postby Legion » Sun, 25th Feb 2007 15:33
Either you use the magic eraser tool or you work directly from the original dds.
Unread postby The Kingpin » Sun, 25th Feb 2007 15:46
Magic eraser.....hmmm....what about cutting it and pasting it? not possible?
The Kingpin
Unread postby Legion » Sun, 25th Feb 2007 15:53
No, would change the colour palette attribute for the transparency colour.
Unread postby The Kingpin » Sun, 25th Feb 2007 17:50
hmm...having a problem. i use the magic eraser, but when i want to save it, it tells me i have too many channels to export (5)......
The Kingpin
Unread postby Eternal_Rocker_Chick » Sun, 25th Feb 2007 17:51
Go on the channel window and delete the opacity one.
Unread postby Legion » Sun, 25th Feb 2007 17:51
I never had that error. Are you sure you're using photoshop properly?
Unread postby Eternal_Rocker_Chick » Sun, 25th Feb 2007 18:08
lol! No, DL i've had that error plenty of times. That's why i leave the teeth opacity to the end, otherwise it messes up
Unread postby The Kingpin » Sun, 25th Feb 2007 18:43
well, i've only just got it, and i haven't used it before. doing quite well though. i've learned how to use the magnetic lasso to highlight the bits i want to change, and did quite an intricate lassoing job blocking out certain patches within the recolour zone, so that i dont accidentally recolour them. now i think i must've touched the teeth when i was recolouring the arms of the rex, because now, when tested in game, it doesn't look right [usual green patch around the teeth]. now, is the opacity channel the Alpha channel? i have RGB, Red, Green, Blue, and Alpha 1. is it the Alpha 1 channel that i need to get rid of?
The Kingpin
Return to Mod/Skin Junkyard
