Paelo trees
Game structure files (fslhunt.ini, eng.txt, research.ini, constant.ini, bldmenu.ini, etc) doubts
Paelo trees
Unread postby Darties » Thu, 5th Jul 2012 16:55
So when I start a game I hate to have to go through the whole map placing Paelo trees manually, is there anyway to start off with Paelo trees completely covering the map? It would save a lot of time and prevent some diseases (as so I've heard that dinos get diseases from normal trees)
Thanks! :grin:
EDIT----------------------------------------------
Nvm found how to do it, if you want to do this here is the link http://jurassicmods.darkbb.com/t750-pal ... as-default
Darties
