Constant .ini
Game structure files (fslhunt.ini, eng.txt, research.ini, constant.ini, bldmenu.ini, etc) doubts
Re: Constant .ini
Unread postby alaska » Mon, 12th Dec 2011 2:43
Ok what are the vector 3 constants, and in the jpog folder what is the col file? I'm changed it around never got results. Are the constants in vector 3 have to do with just color, shades, and other lighting aspects?
alaska
Re: Constant .ini
Unread postby RaptorGrant » Fri, 20th Jan 2012 21:51
Hey guys! im new here on Modding Genesis and I've been searching far and wide on the internet trying to figure out how to save the changes on the file Constant.ini. Im operating on a Windows vista and every time i try to save the changes, it always shows that it is unable to save. Can someone help me with a possible guideline? :shock: please And thank You!!!!!!!!!!!!!!
RaptorGrant
Re: Constant .ini
Unread postby DamnScouse » Sun, 15th Apr 2012 21:33
Right click on the constants.ini file, go to properties, then look in the attributes section at the bottom, make sure "read-only" is unticked
DamnScouse
Re: Constant .ini
Unread postby TheLOSTJoker » Wed, 22nd Feb 2017 18:19
   FollowCamMinPitch = -30;
   FollowCamMaxPitch =  10;
   FollowCamMaxDistanceOffset =  20;
   WorldCamMinPitch = -52;
   WorldCamMaxPitch = 5;
   WorldCamMinDistance =  15;
   WorldCamMaxDistance =  100;
   WorldCamTerrainOffset = -2;
   WorldCamFOVWhenLow =  73;
   WorldCamFOVWhenHigh =  110;
   WorldCamMinFOVHeight =  90;
   WorldCamMaxFOVHeight =  140;
These are camera controls, also I have written about the lines from the DJE mod so the camera can go all the way to the ground, awesome! But does anyone know how to change the mouse wheel zoom speed? Been trying to figure that one out.
TheLOSTJoker
User Title: Park Ranger
Previous
