How to create death duels using existing animations?
FSM files help.
Unread postby rampagingbrach655 » Tue, 8th Jun 2010 13:36
I want to make these two death duels:brach vs trex, and camara vs trex
But how do I use the brach drinking animation to make him pick up the t-rex, then make him rear up and drop the t-rex while rearing, and so when his feet hit the ground, they hit the t-rex and kill it?
Is it possible?
About the camara vs rex deathduel, I want the t-rex to use the same anim that he does when killing spino at the same time that camara rears up, so he will hit camara's belly?And how do I make camara rear up and stomp at the t-rex,causing t-rex to fall, then rear up and stomp a second time to finish it off?
Is this also possible?
I wanted to have these deathduels for my mod pack...
rampagingbrach655
Re: How to create death duels using existing animations?
Unread postby Deviljhodude » Thu, 30th Jun 2011 14:25
IF anyone except the original creators of jpog could do that, then im sure that he'd be working at some gamecompany somewhere and only do things if he (or she) gets no less than 500 dollars for it :x3:
Deviljhodude
Unread postby Spinogator » Fri, 14th Oct 2011 21:59
Actually it doesn't sound that difficult, all you have to do is make them use those animations, fsm modding could accomplish this.
Join The JPOG ZONE by clicking on the image above
Spinogator
Return to Behaviour
