Unlabelled unit folders?
Animal/Building ini, inx and nwt doubts
Unread postby Camarasaur8 » Sat, 4th Feb 2017 15:39
Hi guys, so yesterday I installed JPOG with plans to install some mods and spruce up a childhood favourite in the process. I decided to start with simple stuff and open the data folders up in Notepad and change the stats, however, the vast majority of these folders aren't labelled with anything useful, and there's nothing that says "constant.ini", for example, anywhere. This has also prevented me from activating them mods I have downloaded as well, because I don't know which folders are meant to be replaced with the modded versions. Is there anything I can do, besides extract each file individually and manually examine it?
Camarasaur8
