Dispatching a jeep without visitors!
Animal/Building ini, inx and nwt doubts
Re: Dispatching a jeep without visitors!
Unread postby raptors rule » Sat, 15th Aug 2009 6:39
No it won't they will go in and safari will break down. :D:
raptors rule
User Title: rr
Unread postby Tarbornodon » Mon, 24th Aug 2009 15:08
this is an amazing mod :grin:
Tarborned
Tarbornodon
User Title: dont ignore then prehistoric park pack!!
Unread postby Galox » Mon, 24th Aug 2009 17:47
Cool, good work!!
On a sort of similar note, I've tried combining a few of the jeep/safari files with the Dino file's, to try and get a "Drivable Dino".
No luck :(
It crashes whenever you make a Safari Ride...
Galox
Unread postby The Grim Reaper » Mon, 24th Aug 2009 17:59
Galox wrote:Cool, good work!!
No luck :(
Have you tried modding all of the files? Even the .inx?
If you desire help with modding, please come to my questions page at http://modgenesis.hostingdelivered.com/viewtopic.php?f=58&p=109223#p109154.
The Grim Reaper
User Title: The Grim Reaper, The Personification of Death, The Stealer of Souls, The Ultimate Reality, The Harvester of Mankind, The Swallower of Oceans.
Unread postby Galox » Mon, 24th Aug 2009 18:09
Urm...I'm going to take another look in a minute. When I tried something, I got to build the Safari ride, but when I click "Create a Path" it crashed...
Galox
Unread postby Nick3069 » Wed, 2nd Sep 2009 13:28
SakuraInjektion wrote:I am not sure if you could use a texture file for that either. Once again, I have no idea where texture files are located, but I highly doubt that it is that easy.
The menu button textures are in JPOG\Data\matlibs\gui_Main.tml. The textures in the tml are: bkg4, effects, Menu_Buttons1, Menu_Buttons4, Menu_Buttons7, and Menu_menubkg.
Adding new ones should be easy, Menu_Buttons1 is almost empty and Menu_menubkg has an empty button template, not to mention that you could also use mostly empty textures and put menu buttons in them like FullGreen, which has xbox buttons.
EDIT: Wait, I just found out that the buttons are also in the gui_InGame.tml. I'm not sure which the game uses, gui_InGame.tml or gui_Main.tml.
EDIT2: Never mind, bkg4 and effects are in gui_Main.tml and the rest are in gui_InGame.tml. Sorry.
Spinosaurus hunter wrote:Great mod! But I have a problem. In the safari.ini i can't find the lines that you are talking about. Can someone help?
That's because it's not in the safari.ini, it's in the safari.inx.
Nick3069
User Title: The Raptor King
Unread postby DinoDude » Mon, 28th Sep 2009 3:12
This is perhaps the greatest thing since sliced bread. :lul:
Check out the Novel Canon Mod.
DinoDude
Friendly Herbivore
Friendly Herbivore
User Title: Billy Shears
Unread postby raptorEE » Thu, 10th Dec 2009 23:56
this is yet ANOTHER reason why I need to fix my stupid XP computer so I can put OG on it (like before) and MOD LIKE CRAZY!
I can find Data. I can find *blank*. I can extract it. BUT I CANNOT OPEN IT because it's a .dll file. ALL my files are (are they corrupt, because the .ini and .inx are vital to the game, right?)
actually, wait! my Data file is called Data2 !!!! I have no Data, but the same stuff is in it!
is it beacuse I uninstalled and reinstalled without checking to see if my computer thought it already existed?
I am part raptor. You are meat!!!!!
raptorEE
User Title: Raptor
five stars
Unread postby Raging Raptor » Fri, 11th Dec 2009 0:06
Wow, nice job, I never noticed this until now, Very nice job. One that I actually put in my game. I like. :)
₪"Untutored courage is useless in the face of educated bullets"₪
-General Patton
Raging Raptor
Feisty Herbivore
Feisty Herbivore
User Title: Call me whatever home slice.
Unread postby island maker dude » Sun, 31st Jan 2010 23:47
I haven't been on for a year or so but just read through this thread, thanks a lot for all the praise and support guys!
island maker dude
Unread postby godrex » Sun, 21st Mar 2010 13:06
Woooooooooohooooooooooooooo
you are really a ....ing genius!!!!
godrex
Unread postby Liopleurodon » Mon, 19th Apr 2010 9:42
Dude that sounds great but how did you ever manage to change the inx file??
Liopleurodon
Unread postby Nick3069 » Fri, 23rd Apr 2010 22:50
Liopleurodon wrote:how did you ever manage to change the inx file??
inx files can be modified with any simple text editor, just like ini files. (Microsoft Word doesn't count as a simple text editor, BTW.) It's just that inx are not set by default to be opened with notepad, to fix that, do this:
Right-click on the inx file, click "open" or "open with", a small window will open, check "Select a program from list of installed programms" and click OK, then select Notepad, WordPad or any other simple text editor you want.
Nick3069
Unread postby Alien » Mon, 26th Apr 2010 15:25
this is one of the best mods ever! now i can make even a dinosaur you can drive on your own! tanks a lot
Make way for the bad guy...
Alien
Unread postby nbielinski » Mon, 12th Jul 2010 23:38
How did you edit the inx file I have a vewier and I can change it but when I save the changes I made with note pad I can make a safari ingame and it crashes how would you turn a "file" into a "inx file" HELP!!! :bored:
never mind disregard ever reading the statement above
You dont see them but they see you
nbielinski
