How to make holes/transparency in dino skins "less ugly"
TML and sound file assistance
Unread postby brolyeuphyfusion » Tue, 7th Jun 2016 8:05
If you're familiar with MST, you're familiar with the dinosaur TML footer, right?
00 00 00 00 02 00 02 00 00 00 00 00 01 00 00 00
01 00 00 00 02 00 02 00 02 00 00 00 03 00 00 00
02 00 00 00 03 00 02 00 04 00 00 00 05 00 00 00
You'll find that the 5th column of the footer, or the 5th value of each line of the footer, is either a 02 or a 03. Change them all to 03.
This will make transparent parts of the dinosaur skins look better. Just try it out yourself if you have skins with transparent parts/holes/alpha channels ;)
Screenshot by DPJWei/EchoGreen
The 5th hex value in each footer line seems to control whether a dinosaur's skin is rendered only visible from the outside of the model, or visible from both inside and outside the model. If it's 02, the skin is only visible from the outside, and if it's 03, the skin is rendered visible from both sides of the "model wall".
brolyeuphyfusion
User Title: Sauropodomorphs rule!!!
Re: How to make holes/transparency in dino skins "less ugly"
Unread postby AustinHazFossils » Sat, 17th Sep 2016 12:01
Umm, I don't know the footer of the TML, and how do I find it easily? I don't want ugly holes.
*my dong* finds a way..
AustinHazFossils
User Title: Did you know that I eat fossils for brekkies?
Unread postby AustinHazFossils » Sun, 16th Oct 2016 6:07
Umm, I need an answer, because the holes on some of the skins look really shoot.
AustinHazFossils
Unread postby Troodon » Thu, 20th Oct 2016 20:53
Jaja,oh my friend,the footer of a tml is the footer of a tml!!
What goes after the names of the dinosaurs in a tml!!
Regards my friend!
Troodon
Return to Skinning and sounds
Users browsing this forum: Bing [Bot] and 1 guest
