TML Tools, now with a fixed link
TML and sound file assistance
Re: TML Tools..... Fixed.
Unread postby Raging Raptor » Tue, 6th Oct 2009 21:01
Docszoo wrote:make your new skin into a DDS file. Then, take out all the other skins from the tml, and make them into DDS files. The rest is easy to understand if you can read. I believe if you leave it blank, it will remain the original one. Not sure. Try it out on your own.
I did that, and got the same error Slayer got.
₪"Untutored courage is useless in the face of educated bullets"₪
-General Patton
Raging Raptor
Feisty Herbivore
Feisty Herbivore
User Title: Call me whatever home slice.
Unread postby THE DINOSAUR MAN » Thu, 8th Oct 2009 0:53
me too.
THE DINOSAUR MAN
User Title: An American constitutionalist and a true scientist.
Unread postby Nick3069 » Fri, 9th Oct 2009 4:10
Wow! April? This has been out for a while... How could I have missed it? :facepalm:
This looks a LOT better than TML Builder. I'll try it later and report back, because apparently, there are still problems with it.
Nick3069
User Title: The Raptor King
Unread postby njm1983 » Fri, 23rd Oct 2009 18:35
MastaFoo69 this is a wonderful utility makes building tmls with different skins so easy. the only problem i had was I save the files into the wrong format of DDS, but I got that sorted really quick. I am having a slight problem with the opa files though, in my newly built tml they arent present so my trex has black around his teeth, I can only assume its the same with the styrac and cory also havent checked though. So support for opa files might be a good idea. Unless someone knows how to solve this problem.
njm1983
Unread postby Nick3069 » Fri, 23rd Oct 2009 20:33
The reason why you have opacity (opa) problem is because DDS includes the opacity information in it's code, like PNG and GIF and unlike BMP which requires 2 files, a bitmap and an opacity map.
I'm guessing you were using Convert CCT, try using Dragon UNpacker to export the DDS.
viewtopic.php?f=48&t=5361
Nick3069
Unread postby Clonehunter » Fri, 23rd Oct 2009 22:04
.NET is the paint program right? Anywyas, I cant figure out how to work this! I'm trying to make a ne skin with it (for CCM :) ) But it doesnt work. When I click build .tml it gives me an error. Am I sopposed to do something with those other blank spaces? And what does output path meen? The Matlibs folder? Thier is also NO readme file included as it says.
[b]So, I like, Doom and stuff... [/b]
Clonehunter
User Title: No John, you are the Demons
Unread postby Raging Raptor » Fri, 23rd Oct 2009 23:10
Nick3069 wrote:The reason why you have opacity (opa) problem is because DDS includes the opacity information in it's code, like PNG and GIF and unlike BMP which requires 2 files, a bitmap and an opacity map.
That wasn't the problem, and that isn't the solution.
-General Patton
Raging Raptor
Feisty Herbivore
Feisty Herbivore
Unread postby njm1983 » Sat, 24th Oct 2009 15:42
Thanks nick, I'll try that program out and hopefully it works. You're most likely correct cause it seems all the opacity is missing from the texture, so if converting the dds to bmp does pull apart the layers that would make sense. If I still get the same issue I'll post back in here.
njm1983
Unread postby T-rex Hunter » Sat, 24th Oct 2009 20:06
nice this program helps a lot Docszoo was right it didnt work at first THANKS MATE :clap: :clap: :clap:
T-rex Hunter
Unread postby just someone » Wed, 11th Nov 2009 13:06
:clap: omg that is sweet!!!! it helps a loth, outstanding tool THANK YOU!!!! :clap:
but i have a question, well the tool is perfect but how can i extract the DDS files from the TML's i have (cause most downloads comes in TML format) so i can recombinates the DDS to get all the skins i want for each digsites even if they come from different TML files?
for example, i want to combinate i the same flaming cliffs TML a raptors and a galli skins which are from 2 differents flaming cliffs TML and thanks to your tool, it can be done easily! , but all i need to know is how to extract DDS from TML...
is there a tool for that? or how can it be done??
just someone
Unread postby Nick3069 » Thu, 12th Nov 2009 1:14
just someone wrote:how can i extract the DDS files from the TML's
Here you go:
viewtopic.php?f=48&t=5361&p=117165#p117165
Nick3069
Unread postby just someone » Thu, 12th Nov 2009 12:09
thank you Nick3069 !!!!! :clap:
(i have also posted a new link to download at the end of your tread cause yours was dead :sweatdrop: )
just someone
Unread postby Mattsugaia » Wed, 25th Nov 2009 23:35
Could you upload it without .NET Framework? I already have it installed, and wish not have to download a bigger file size.
Matt: Paiyne, Hitsu123
"Mistakes are always forgivable, if one has the courage to admit them." - Bruce Lee
Mattsugaia
User Title: Hitsu123, bringer of Paiyne.
Unread postby MastaFoo69 » Fri, 27th Nov 2009 21:46
Mattsugaia wrote:Could you upload it without .NET Framework? I already have it installed, and wish not have to download a bigger file size.
Well, lets see, um.. no. I uploaded the program with the .Net Framework as its own component. if you have the framework, congrats! want a cookie or a small parade? or a small parade of cookies perhaps? Many people do not have the .NET framework already installed, and need it, so its in the download. dont want it? fine by me, delete the file that has it. :zaru:
MastaFoo69
G.E.P. member
G.E.P. member
Unread postby Mattsugaia » Sat, 28th Nov 2009 19:40
Well, if I download a big file, the file won't download because of my crappy internet! :zaru:
Anyways I won't be downloading it. It's not as great as I thought it would be.
Mattsugaia
Return to Skinning and sounds
