TML Tools, now with a fixed link
TML and sound file assistance
Unread postby MastaFoo69 » Fri, 24th Apr 2009 19:35
Well Everyone, .TML Tools is up and finally finished. TML Builder was too inefficient, and I wanted a better program to help the community more. :amused:
Sadly, however, I did break down and upload the program to filebeam, because DL was a tid-bit too lazy to fix attachments. :bored:
Anywhoo, There is an included readme file and the .NET framework is included. So, Without further ado, I give you..... TML TOOLS!!!!!!!!!
DOWNLOAD NOW!
UPDATE: September 3, 2013, 1:37 EST
fixed link on this page
UPDATE: April 27, 2009, 12:23 PM EST
I have fixed it. download away
UPDATE: April 28, 2009, 1:03 PM EST
I have fixed it.... Properly this time. There was a tid bit of a version error in the past two releases, and now there is not.
I also have a few screenies:
UPDATE: Tuesday, May 12, 2009 @ 12:23 PM EST
System Requirements:
Supported Operating Systems: Windows Server 2003; Windows Server 2008; Windows Vista; Windows XP
Processor: 400 MHz Pentium processor or equivalent (Minimum); 1GHz Pentium processor or equivalent (Recommended)
RAM:96 MB (Minimum); 256 MB (Recommended)
Hard Disk: Up to 500 MB of available space may be required
Display: 800 x 600, 256 colors (Minimum); 1024 x 768 high color, 32-bit (Recommended)
Software required: .NET framework 3.5 (run the installer that comes with the program)
How To Use
I designed .TML TOOLS to be as user friendly as possible. To build the .TML of your dreams simply do the following:
1) Select the desired digsite.
2) Select the desired .dds file for each dinosaur, both dead and alive.
3) Name your .tml file. Some users think that the name box is for a file location. It is not. You just name your .tml file. If you want it to be, lets say "dinos_judithriver_B" type: "dinos_judithriver_B". You do not, I repeat DO NOT have to type in a file path OR the '.tml' part.
4) Hit the "Build my TML!" button. The output .tml will be in the ROOT of the TML TOOLS folder.
MastaFoo69
G.E.P. member
G.E.P. member
Re: TML Tools
Unread postby ROBOT_ENTERTAIN_XBOX » Sat, 25th Apr 2009 2:00
Wow, sounds kool. :) Promising?
User Title: Diablo King
Re: TML Tools
Unread postby Dino Man155 » Sun, 26th Apr 2009 1:42
it wont wrok! :bored:
and where can i find a cct converter?
Um....whats that smell?smells like............roten flesh......is that a Rex!!!!!!!!!!!!!!
Dino Man155
User Title: Ian Malcom
Re: TML Tools
Unread postby Baryonyx » Sun, 26th Apr 2009 7:35
Just wanted to let you know that for some reason,the only thing i can select is the first skin in the tml.
Baryonyx
Feisty Herbivore
Feisty Herbivore
User Title: What now?
Re: TML Tools
Unread postby Koffein » Sun, 26th Apr 2009 8:27
Great tool, but I'm having the same problem as well, the only box I can add a skin to is the top left. I can type in the paths manually but get this error when I try to build the tml:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Empty path name is not legal.
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
   at System.IO.File.ReadAllBytes(String path)
   at Microsoft.VisualBasic.MyServices.FileSystemProxy.ReadAllBytes(String file)
   at TML_Tools_Attempt.Form1.Button1_Click(Object sender, EventArgs e) in I:\TML Tools\TML Tools\TML Tools\Form1.vb:line 43
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
TML Tools
    Assembly Version: 1.1.0.9
    Win32 Version: 1.3.0.0
    CodeBase: file:///D:/Spel/Universal%20Interactive/Blue%20Tongue%20Software/Jurassic%20Park%20Operation%20Genesis/JPOG/Modding%20Genesis/TML%20Tools%20Final%20Build/TML%20Tools.exe
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
EDIT: Oh, yeah. I forgot. One request for an update would be to add support for opacity maps.
Koffein
G.E.P. member
G.E.P. member
User Title: Mostly awesome
Re: TML Tools
Unread postby Legion » Sun, 26th Apr 2009 12:00
Unstickied until Masta can come up with a bugfix/tutorial/a more detailed post
Re: TML Tools
Unread postby MastaFoo69 » Sun, 26th Apr 2009 22:17
:sweatdrop: omg frack. ok um.... ill have the problem fixed monday, check back around 2:30 PM EST.
(I know what the issue is, and im gunna fix it immediatly)
MastaFoo69
G.E.P. member
G.E.P. member
Re: TML Tools
Unread postby Destroyer » Sun, 26th Apr 2009 23:18
Dude same things happening to me and there's another prob. When I tried the setup it said a problem accored (bad spelling).
Check out my videos at http://www.youtube.com/user/Carnotaurus98?feature=mhsn
I'll be posting videos and documentaries on my mods.
[img]http://img7.uploadhouse.com/fileuploads/3884/38846670f11c467b54c324edc7f85a139d1c10c.jpg[/img]
Destroyer
User Title: A kid who knows a lot about dinosaurs even more than a scientist.
Re: TML Tools
Unread postby Dino Man155 » Mon, 27th Apr 2009 0:15
TML Tools is wiging out!!!it wont open but it gives me a error rport! :bored:
Reason: Don't smilie spam!
Dino Man155
Re: TML Tools
Unread postby Koffein » Mon, 27th Apr 2009 9:44
Dino Man155 wrote:TML Tools is wiging out!!!it wont open but it gives me a error rport! :bored:
Did you install .NET first? The setup file is called dotnetfx35setup.exe
Koffein
G.E.P. member
G.E.P. member
Re: TML Tools
Unread postby Destroyer » Mon, 27th Apr 2009 12:30
When is the debugged version going to come out?
Destroyer
Re: TML Tools
Unread postby Baryonyx » Mon, 27th Apr 2009 13:59
Destroyer wrote:When is the debugged version going to come out?
Be patient.Look at this post.
MastaFoo69 wrote::sweatdrop: omg frack. ok um.... ill have the problem fixed monday, check back around 2:30 PM EST.
Baryonyx
Feisty Herbivore
Feisty Herbivore
Re: TML Tools..... Fixed.
Unread postby MastaFoo69 » Mon, 27th Apr 2009 17:25
Its fixed. I think. It seems to work now, so yeah. :stoned:
MastaFoo69
G.E.P. member
G.E.P. member
Unread postby Koffein » Mon, 27th Apr 2009 18:20
Creates the output tml nicely now. It does get an error if you try to specify a path for the output though. In game, all dinos with that tml turn white.
Koffein
G.E.P. member
G.E.P. member
Unread postby MastaFoo69 » Mon, 27th Apr 2009 19:07
wait, are you saying that all tmls have white dinos? cuz they shouldnt.
MastaFoo69
G.E.P. member
G.E.P. member
Return to Skinning and sounds
