editing the mission times
Don't know how to add a mission? Or change an island? Come here!
Unread postby ch4dg » Sun, 9th Oct 2011 20:19
hi,
does anyone know how to edit the mission times....my daughter (and me) are struggling
thanks
ch4dg
Re: editing the mission times
Unread postby Reprieve » Sun, 9th Oct 2011 20:34
Go to:
Universal Interactive->Blue Tongue Software->Jurassic Park Operation Genesis->JPOG->Data->Missions
Open the .MIS file of the mission you're stuck on (you might need to use babelpad, but notepad should work).
Scroll to
      ; // Enable and start mission timer
      ;action EnableMissionTimer(true)
      ;action StartMissionTimer(600)
(This is taken from "Safari1.MIS" so don't worry if yours is different)
Alter as desired.
Report back on whether this works so a mod can be made for general release (I, alas, cannot test it as I don't have my copy of JPOG with me).
Reprieve
User Title: flagellum dei
Unread postby ch4dg » Mon, 10th Oct 2011 20:52
thats brilliant, worked first time (pardon the pun)
i looked everywhere but couldn't work out how to open the MIS files, i couldnt open it with notepad but that babel worked perfectly other than that you were spot on
thanks :clap:
ch4dg
Unread postby Reprieve » Tue, 11th Oct 2011 13:32
Can I just ask what you changed them too?
Reprieve
Unread postby ch4dg » Tue, 11th Oct 2011 19:13
yeah sure its the least i owe you :amused:
in your example its where it says 600, i changed it from 540 to 100000 which gave me about 83 minutes
ch4dg
Unread postby Reprieve » Tue, 11th Oct 2011 20:50
Ah, that's good. Sometimes it won't let you add extra digits to numbers.
Reprieve
Return to Islands & Missions
