How to make 100% dino DNA in Site B
Don't know how to add a mission? Or change an island? Come here!
Unread postby Dino scientist » Sat, 6th Mar 2010 2:31
Hi, I've just unlocked the Site B. I try to make all the dinosaur species DNA 100% when the game starts, not by unlocking the dig sites. I try to edit the Site B.ini by inserting
action SetAllSpeciesDinoDNA(100);
I got this idea from the mission RngrAttk1, but everytime I click on a hatchery the game crashes.
If anyone knows how to fix this, please reply. :pleased:
Dino scientist
Re: How to make 100% dino DNA in Site B
Unread postby Laddaustein » Sun, 7th Mar 2010 0:20
um... on Site B, you already start with 100% DNA for all the dinos...
Laddaustein
User Title: Everlasting Darkness
Unread postby Dino scientist » Sun, 7th Mar 2010 3:15
No, I mean to get 100% dino DNA for all species without having the Fossil Hunt Dialog to appear. In GEP v2, you start site B with all species dna 100% immediately, without having to choose the digsites. But since GEP v2 had plenty of problems, I had to reinstall the game. I remembered they had
but when I put it in Site B, the game crashes everytime I select a hatchery
Dino scientist
Unread postby Dryosaurus_Rex » Tue, 9th Mar 2010 19:49
Could you just go into the code and change the total selectable digsites from 5 to 9? Im not sure what the line is but its possible.
Dryosaurus_Rex
Unread postby Dino scientist » Thu, 11th Mar 2010 10:14
It is possible and I've tried. I opened fslhunt.ini and scrolled down to the last lines.
There, it is stated the maximum number of digsites in PS2, PC and Xbox. I changed the limit from 5 to 9 for the PC. But alas,it was useless. :amused:
If say those that made GEP v2 revealed information about their SiteB.ini, then it would be easier. I recalled they used
I also got the idea from mission files. I put it in the missioninit state and it worked (partly). When you start and check the dinosaur summary, all species are said to have 100% DNA, but when you click a hatchery the game instantly crashes. I never had this much trouble when I edited FSM files (which was remarkable and disastrous) :sweatdrop:
So if anyone has any ideas, please help!
Thank you
Dino scientist
Return to Islands & Missions
