Terraforming Islands.
Don't know how to add a mission? Or change an island? Come here!
Unread postby -Cozur » Sat, 28th Mar 2009 14:52
Yes, there is countless threads about this, but I haven't been able to find the answer I'm looking for.
The terraform mods I've found so far have all been making mountains that just look like replicas of the hills.
What I'm looking for is the ability to make mountains, not oversized hills.
The below sentence is false.
The above sentence is true.
-Cozur
Re: Terraforming Islands.
Unread postby Baryonyx » Sat, 28th Mar 2009 14:56
TerraFormMountainLevel0Width = 128;
TerraFormMountainLevel1Width = 64;
TerraFormMountainLevel2Width = 32;
TerraFormLakeLevel0Width = 32;
TerraFormLakeLevel1Width = 64;
TerraFormLakeLevel2Width = 128;
TerraFormFlatLevel0Width = 32;
TerraFormFlatLevel1Width = 64;
TerraFormFlatLevel2Width = 128;
TerraFormHillLevel0Width = 126;
TerraFormHillLevel1Width = 64;
TerraFormHillLevel2Width = 32;
TerraFormMountainDeformRatio = 1;
TerraFormLakeDeformRatio = 1;
TerraFormHillDeformRatio = 1;
TerraFormFlatDeformRatio = 1;
TreePlace0Width = 16;
TreePlace1Width = 32;
TreePlace2Width = 64;
Find the lines and replace with these.These are the edited lines.If you click enough it usually makes the mountains higher.
Baryonyx
Feisty Herbivore
Feisty Herbivore
User Title: What now?
Unread postby -Cozur » Sat, 28th Mar 2009 15:06
Okay, is this change compatible with the GEP?
-Cozur
Unread postby Baryonyx » Sat, 28th Mar 2009 15:12
It affects the changed terraform values of GEP.
Baryonyx
Feisty Herbivore
Feisty Herbivore
Unread postby -Cozur » Sat, 28th Mar 2009 15:43
Well, having incorporated the changes into my game, all I get is huge hills. No mountains like the default ones formed when you create a new island.
-Cozur
Unread postby Baryonyx » Sat, 28th Mar 2009 15:57
That's the closest you can get to mountains.If you use the flatten tool properly you could create jagged mountains.Make mountains on mountains again and you can get it larger and higher.
Baryonyx
Feisty Herbivore
Feisty Herbivore
Unread postby Integrity Zero » Sun, 29th Mar 2009 5:39
Be warned though, you don't want to increase the values too much, otherwise the game will crash after a very short period of time.
You're back in His arms again
Integrity Zero
User Title: Call me Izzy.
Unread postby Docszoo » Mon, 30th Mar 2009 21:23
Replace the following values with the ones in the constant ini. This is compatable with the GEP up to repacing the cam view and mountain levels, and I guess tree placement.
FollowCamMinPitch = -90;
FollowCamMaxPitch = 20;
FollowCamMaxDistanceOffset = 80;
WorldCamMinPitch = -30;
WorldCamMaxPitch = -1;
WorldCamMinDistance = 1;
WorldCamMaxDistance = 145;
WorldCamTerrainOffset = -2;
WorldCamFOVWhenLow = 60;
WorldCamFOVWhenHigh = 60;
WorldCamMinFOVHeight = 10;
WorldCamMaxFOVHeight = 100;
-Andrew
Docszoo
User Title: Docszoo
Unread postby -Cozur » Tue, 7th Apr 2009 14:45
How do I make this compatible with the GEP?
-Cozur
Unread postby Docszoo » Tue, 7th Apr 2009 15:53
Docszoo wrote:Replace the following values with the ones in the constant ini. This is compatable with the GEP up to repacing the cam view and mountain levels, and I guess tree placement.
It is. The GEP Messed with those exact values. Everything else not listed in the coding stays the same.
-Andrew
Docszoo
User Title: Docszoo
Unread postby Tarbornodon » Tue, 4th Aug 2009 16:35
i tried it to it dosent seem to work?! :x3:
Tarborned
Tarbornodon
User Title: dont ignore then prehistoric park pack!!
Unread postby Docszoo » Tue, 4th Aug 2009 17:04
Have you even read through the entire thread?
-Andrew
Docszoo
User Title: Docszoo
Unread postby Tarbornodon » Wed, 5th Aug 2009 10:35
yes
ive have got gep and when i start up game it loads up onto main menu
and when i click on site b or og the screen goes blank and sends me an error report.
Tarborned
Tarbornodon
Unread postby soulix121202 » Fri, 7th Aug 2009 5:12
I saw this video in youtube, where there's instead of mountains there's walls of grass, hills I don't know what to call them. But here's the video
Anyone knows how to do this long slopping hill??? :argh:
"God creates Dinosaurs. God destroys Dinosaurs. God creates men. Men destroys God. Men creates Dinosaurs." "Dinosaurs, eat men. And then women inherits the Earth"
Ian Malcom and Ellie Satler, Jurassic Park
soulix121202
Friendly Herbivore
Friendly Herbivore
Unread postby ceratosaurus » Thu, 31st Dec 2009 0:13
it's on JPL search "dvrex terraform mod".
ceratosaurus
User Title: The master of Ceratosaurus Nasicornis
Return to Islands & Missions
