Build powerbox in the park
Unread postby yochenhsieh » Tue, 19th Jun 2007 10:33
Description
Allows the user to build the hatchery powerbox in there park
Known Issues
None
Tutorial
First, open Units\hatchpwr.ini, Insert
    FootprintX= 1 ;
    FootprintY= 1 ;
Above "UseINX=1".
Then open Units\hatchpwr.inx, Insert
    NumExits=1;
    Exit[ 0 ] {
        PosX=1;
        PosY=0;
      Type=ArrowRight;
Inside Building {} section. This will let you change powerox's facing.
And insert
PreviewScene
   CamPosition = {0, -6.5, -10};
   CamAngle = 30;
   Model
      Model = powerbox;
      Position = {0, 0, 0};
   Model
      Model = GrndPW;
Above "Particle". This make the preview scene of powerbox consistent with other buildings.
Go to your GUI folder, open bldmenu.ini, insert
         unit = hatchpwr;
inside the section you want. I place it inside "security".
Open texture.gui, insert this line into anywhere you want.
Menu_ParkManager_hatchpwr   Menu_Buttons5   0   64   64   64   0   false   false   false;
This make powerbox use hatchery icon in build menu. Or you can use other icon for it.
You should now be able to build the powerbox, though it doesn't have any real purpose... lol
yochenhsieh
Re: Build powerbox in the park
Unread postby The Witch King » Tue, 19th Jun 2007 11:48
A pretty basic mod. Its nice to see old mods making a come back.
The Witch King
Park Ranger
Park Ranger
User Title: Lord of the Nazgûl
Unread postby yochenhsieh » Tue, 19th Jun 2007 15:33
Updates:
1)Found another nice icon, just change Menu_Buttons5 to Menu_Buttons7. It's a symbol of electricity.
2)If you want to build powerbox on roads, insert
[code]
RoadAttachment = 1;
[/code]
inside Building {} section.
[url=http://MystiPix.com/Image/ossornji][img]http://MystiPix.com/ossornji.jpg[/img][/url]
yochenhsieh
Unread postby PONCHO » Wed, 20th Jun 2007 17:20
Will this replace the tombstone?
PONCHO
Unread postby Legion » Wed, 20th Jun 2007 17:55
PONCHO wrote:Will this replace the tombstone?
no.
Unread postby djv1016 » Fri, 22nd Jun 2007 0:33
dumb question. where's texture.gui? i can't find it.
djv1016
Unread postby ceratosaurus » Fri, 22nd Jun 2007 6:09
I cant find it either i'm wondering if it exists at all
ceratosaurus
User Title: The master of Ceratosaurus Nasicornis
Unread postby Legion » Fri, 22nd Jun 2007 9:13
djv1016 wrote:dumb question. where's texture.gui? i can't find it.
he meant main.gui
Unread postby yochenhsieh » Fri, 22nd Jun 2007 12:40
What is main.gui?
... Wait, I should know it. My JPOG is a different version to yours. :P
http://MystiPix.com/Image/osuqzxrf
http://MystiPix.com/Image/osurapwx
That probably explains why my "Play the park of missions and exercise" doesn't work for you... :(
yochenhsieh
Unread postby Eternal_Rocker_Chick » Fri, 22nd Jun 2007 17:35
Wow, that's really interesting. What other things are different?
User Title: Talking Duck
Unread postby yochenhsieh » Fri, 22nd Jun 2007 17:45
I'm not sure.:P
At least the simjp.exe is different so that this version can load different locales via registry. I can play English, French, German, Italian, Spanish, Japanese, Korean, and Chinese(Traditional) version of JPOG.
There're 2 additional Japanese-voiced intro movie in movies folder, and some additional tml files for CJK fonts.
http://MystiPix.com/Image/osuveopj
yochenhsieh
Unread postby Eternal_Rocker_Chick » Fri, 22nd Jun 2007 18:48
I don't have the ingame.tml either. Strange. What's inside the ingame.tml?
Unread postby yochenhsieh » Sat, 23rd Jun 2007 0:58
GUI_InGame.tml includes
cfilter
menu_buttons1,2,4,7
menu_menubkg
sea
sniper1
upgrades_purchase
upgrades_upgrades1,2
mostly icons and ui pics.
yochenhsieh
Unread postby Eternal_Rocker_Chick » Sat, 23rd Jun 2007 9:20
No, ignore me. We do have that TML. I've just never noticed it before
Unread postby Triceraptor Rex » Wed, 8th Aug 2007 9:04
How do you change the prices? WHich file?
Triceraptor Rex
Mod Tester
User Title: Experiment #762 (55% Raptor/35% Rex/20% Trike)
