Dinosaur Statues
Dinosaur Statues
Unread postby Trassic » Tue, 9th Sep 2008 1:18
Here i found out how to get Dino's on the side of Paths. (like the lamps and speakers)
just go into your roadadd .ini and find any line such as...
Type
      Model=InfoLrg;
      Style=TIntersection;
      Weight=10;
   Type
      Model=InfoSml;
      Weight=15;
then just switch the thing you dont want into the dino that you want. I find that medium and small dinos work better that big dinos.
here are some pics of the statues (they dont have a skin so i call them statues :P)
pics are at this link...
http://jurassicmods.darkbb.com/mods-f2/dino-staues-t11.htm
Trassic
User Title: Member/Island Designer
Re: Dinosaur Statues
Unread postby JPnick13 » Tue, 9th Sep 2008 19:55
cool man!
JPnick13
Unread postby godzillaman » Sat, 13th Sep 2008 15:05
Do they automatically loose their skins? Or are the real dinosaurs skinless?
The CSP has been released! Check it out here!
godzillaman
User Title: Chuck Norris's Apprentice
Unread postby Trassic » Sat, 13th Sep 2008 19:48
the real dinos have skins
the "Statues" on the side of the road Will not have skins
Trassic
Unread postby godzillaman » Sat, 13th Sep 2008 21:56
Cool! Hey, would it be possible to take the raptor statue out of the of the rest area and use that as a statue? That would be cool.
godzillaman
Unread postby Trassic » Sat, 13th Sep 2008 22:08
if it is considered a seperate model from the rest area
Trassic
Unread postby godzillaman » Sat, 13th Sep 2008 22:23
Somebody should find out! :zaru:
godzillaman
Unread postby maximusthedark » Sat, 20th Sep 2008 15:08
the dino statues have skins right...? maybe you could simply place the
Model="dinomodel";
Skin= 1 ;
somewhere... and it will have a skin...
To announce that there must be no criticism of the President, or that we are to stand by the President, right or wrong, is not only unpatriotic and servile, but is morally treasonable… — Theodore Roosevelt
maximusthedark
User Title: Catervarii, mediocre artist...
Unread postby Trassic » Sat, 20th Sep 2008 18:19
hmm i never thought of that.. ill go test it as soon as i have the time (working on Brochure isla nublar)
Trassic
Unread postby IronWarrior » Sun, 21st Sep 2008 14:18
If you add these to your park, do they really count, like can the vistors see them and well be happy about it or is it just for you to make your park look pretty to your eyes?
IronWarrior
Unread postby Trassic » Sun, 21st Sep 2008 15:46
IronWarrior wrote:If you add these to your park, do they really count, like can the vistors see them and well be happy about it or is it just for you to make your park look pretty to your eyes?
if you mean the visitor's will acknowledge them no they wont. its just for scenery like the other things on the side of the road
maximusthedark wrote:the dino statues have skins right...? maybe you could simply place the
Model="dinomodel";
Skin= 1 ;
i just tried that and no it doesnt work, its still the same skinless model
Trassic
Unread postby godzillaman » Mon, 22nd Sep 2008 2:16
As Gopher said on JM,
We should reskin them to look like marble.
:zaru:
godzillaman
Unread postby Trassic » Mon, 22nd Sep 2008 3:57
problem is how do you skin them?
Trassic
Unread postby maximusthedark » Fri, 26th Sep 2008 2:38
nay... JPL managed to create a dino carcass statue... and when I opened it's .ini file it contains the
Model="TRex";
skin=2
command...
so.. I can change it to either living or dead skin Rex...
maximusthedark
Unread postby Trassic » Fri, 26th Sep 2008 2:56
really? i never tried the dead skin never thought of it
Trassic
