Adding Digsites
Re: Adding Digsites
Unread postby SlayerVI » Sat, 6th Jun 2009 20:13
Okay, first off, I know that this is a super old topic. But I have a question that actually applies to the topic.
About the location of the digsites, the positions (EX. Flaming Cliffs locations are {226, 80} and {397, 83}) don't match up to real coordinates, so how would I place something at a certain coordinate? Or is the position a certain set of pixels on an image? Please respond, and please, don't warn me because I read the entire topic and it doesn't look like I can get an answer. *Prepares to get beaten within an inch of life with warn stick*
Kill 'em All--Bow down to the Phantom Lord...
Ride the Lightning--I have lost the will to live... simply nothing more to give...
Master of Puppets--Master! MASTER!!
And Justice For All...--Believer Deceiver! Day in day out live my life through you!
SlayerVI
User Title: Ride the Lightning
Re: Adding Digsites
Unread postby Legion » Sun, 7th Jun 2009 10:29
You won't get warned, this is a relevant question.
See, I always positioned my digsites on a try and check setting, but if you want to know for sure, extract the world map from its tml, open it in your image editing software and check the coordinates where the digsite would be.
Re: Adding Digsites
Unread postby SlayerVI » Sun, 7th Jun 2009 16:04
Thanks, I'll try that. Which file is the world map in? You say it's in a TML, but what would the name be, and what file would it be in?
EDIT: Is this the correct format for adding dinos?
// DASANPU ---------------------------------------------------------------
HuntingGround[Dashanpu]
   title      = $FossilHunt_TendaguruBeds_Title;
   period      = Jurassic;
   location   = Asia;
   matlib      = "dinos_dashanpu";
   reqdinos   = { brach, kentro, Allo, SRaptor };
   linkedtoset = 1;   // Linked to an unlocking set
   cost      = 0;
   gold      = 20;
//   position   = {226, 10};
   position   = {397, 40};
   texture      = "FslHunt_fossil2";
   DigSite[river1]
      type         = plains;
      texture         = "FslHunt_DigSite_1";
      position      = {168, 53};
      title         = $FossilHunt_DigSite_River;
      teams         = 2;
      digtime         = 1.0;
   DigSite[river2]
      type         = plains;
      texture         = "FslHunt_DigSite_2";
      position      = {213, 149};
      teams         = 3;
      digtime         = 1.0;
   DigSite[mountain]
      type         = mountain;
      texture         = "FslHunt_DigSite_3";
      position      = {67, 211};
      title         = $FossilHunt_DigSite_Plains;
      teams         = 4;
      digtime         = 1.0;
This is a new digsite for the Dashanpu formation in China. Tell me if there's anything I need to change.
SlayerVI
Re: Adding Digsites
Unread postby Anewguy » Fri, 13th Nov 2009 16:14
Is this an old topic?
Well anyway can we make our own TML file?
Copying some skins from different TMLs.
Aaargh its coming... Its coming...... ITS ITS....... cow?
Anewguy
Re: Adding Digsites
Unread postby Reprieve » Fri, 13th Nov 2009 17:43
Yes it is, check the age of the last post
Reprieve
User Title: flagellum dei
Re: Adding Digsites
Unread postby Nick3069 » Fri, 13th Nov 2009 22:18
Anewguy wrote:can we make our own TML file?
Yes, make a dino skin TML and call it either decals.tml, terrain.tml, or gui_frontend.tml. All 3 of those names are not used, (except for gui_frontend.tml, but it contains nothing but the TML header) but are recognized by the EXE. I'm surprised nobody used this trick yet. :facepalm:
There is a more complex way to do this, and I'm planning on making a tutorial about it eventually.
Nick3069
User Title: The Raptor King
Re: Adding Digsites
Unread postby Anewguy » Sun, 15th Nov 2009 18:42
[/quote]
There is a more complex way to do this, and I'm planning on making a tutorial about it eventually.[/quote]
Good :stoned:
Anewguy
Re: Adding Digsites
Unread postby Raging Raptor » Fri, 20th Nov 2009 0:36
I would prefer a non complex way to do things. Production of something useful requires user-simplicity over user-complexity. Take something complex (like that) and make it simple. That's how you can make something useful. :)
₪"Untutored courage is useless in the face of educated bullets"₪
-General Patton
Raging Raptor
Feisty Herbivore
Feisty Herbivore
User Title: Call me whatever home slice.
Re: Adding Digsites
Unread postby Nick3069 » Fri, 20th Nov 2009 4:03
Raging Raptor wrote:I would prefer a non complex way to do things.
I just said the easy way. :hehee: Sure, I didn't go into to many details because most of the other information you need is on page 1. Besides, the "more complex way" is simply editing a file with a HEX editor, and almost every modder here knows how to do that.
Nick3069
Re: Adding Digsites
Unread postby Raging Raptor » Fri, 20th Nov 2009 22:57
I thought you meant that there is an even MORE complex way of doing this, and you where going to post a tutorial of it. That's sure what it sounded like.
-General Patton
Raging Raptor
Feisty Herbivore
Feisty Herbivore
Re: Adding Digsites
Unread postby barret-rex » Sat, 5th Nov 2011 16:40
SlayerVI wrote:Thanks, I'll try that. Which file is the world map in? You say it's in a TML, but what would the name be, and what file would it be in?
   period      = Jurassic;
   location   = Asia;
   cost      = 0;
   gold      = 20;
   DigSite[river1]
      type         = plains;
      teams         = 2;
      digtime         = 1.0;
   DigSite[river2]
      type         = plains;
      teams         = 3;
      digtime         = 1.0;
   DigSite[mountain]
      type         = mountain;
      teams         = 4;
      digtime         = 1.0;
With the addition of DIG SITES MAY BE USED FOR NEW DINOSAURS try it
progressing in tmd editing
barret-rex
User Title: the one jurassic park with sarcosuchus
Re: Adding Digsites
Unread postby jfgoofy » Thu, 5th Jul 2012 0:31
Can we make them have more dinos without tmls?
jfgoofy
Re: Adding Digsites
Unread postby Dark_Ansem » Thu, 5th Jul 2012 23:08
can you put more, realistic digsites in the next GEP version? please?
Dark_Ansem
Re: Adding Digsites
Unread postby Green Grass » Sat, 21st Jul 2012 10:02
Hi, I created a new dig site and I would like to put it in madagasgar but I have absolutely no idea what the coordinates would be so could someone please tell me. Thanks :) .
Nyan?
Nyan?
Heheheheheh!
Green Grass
User Title: Gaghiel
Previous
