Adding Digsites
Unread postby Legion » Wed, 23rd May 2007 10:52
It crashes because the digsite isn't recognized by the game - it fetches the diggy from the exe, not from the folder.. A way me and ERC thought of, was using the same digsites, but request different dinos in the DinoS = {} part of the digsite, since can get 7 dinos (normal and dead skin) per each diggy tml.
Unread postby Second Illiteration » Wed, 23rd May 2007 15:23
PeterTheReaper wrote:It crashes because the digsite isn't recognized by the game - it fetches the diggy from the exe, not from the folder.. A way me and ERC thought of, was using the same digsites, but request different dinos in the DinoS = {} part of the digsite, since can get 7 dinos (normal and dead skin) per each diggy tml.
Yeah I pretty much KNEW it wouldn't be that easy but one can always hope.
Second Illiteration
Unread postby Dragonflie » Sat, 26th May 2007 0:39
I can't find the place for step #5... I am new to this , but not how to do it sorta.
Fear me!!! Hey why r u laughing? I SAID FEAR ME!!!
Dragonflie
Unread postby Dark Star » Sat, 26th May 2007 0:57
it's in the Data/Locales folder.
Dark Star
Unread postby Dragonflie » Sat, 26th May 2007 1:02
Locales? Where is the "locales" folder? Or are you just describing the data folder?
Dragonflie
Unread postby Dark Star » Sat, 26th May 2007 1:13
I mean the Locales folder is in the Data folder.
Dark Star
Re: Adding Digsites
Unread postby Dilophosaurus Rex » Tue, 17th Jul 2007 17:30
Is this possible?
If i create a new digsite in South America (a copy of Chenini), and add my Carcha clone Giganoto, my Spino clone Irritator, and my Ourano clone Iguanodon there, to leave out Carcha, Spino, and Ourano?
Or will i have to put those three there as well?
EDIT: Never mind. I figured it out, but not with the Chenini thing, since i can't find the right coordinates for a South-American digsite. I added a copy of Judith River B, and replaced T-Rex with Tarbosaurus in the FslHunt.ini file, and it worked. When i unlocked that digsite on Site B, i got Corythosaurus, Styracosaurus and Tarbosaurus!
Dilophosaurus Rex
Re: Adding Digsites
Unread postby The_Almighty_Emperor » Tue, 17th Jul 2007 20:26
Cool, can you put it up for download, please.
Re: Adding Digsites
Unread postby Dilophosaurus Rex » Tue, 17th Jul 2007 22:02
You can easily do this yourself. I'll PM you the way.
Dilophosaurus Rex
Re: Adding Digsites
Unread postby The_Almighty_Emperor » Tue, 17th Jul 2007 22:40
thanks a lot Dilo-rex :)
Re: Adding Digsites
Unread postby Dilophosaurus Rex » Wed, 18th Jul 2007 9:27
It's ok.
I am having some trouble though with changing the continent of digsites. I tried to copy Flaming Cliffs over to North America, and added coordinates that would put it above Judith River A but it ended up in the top left of the digsite selection screen.
I'm going to look into that a bit more.
Dilophosaurus Rex
Re: Adding Digsites
Unread postby Legion » Wed, 18th Jul 2007 10:17
Dilophosaurus Rex wrote:It's ok.
Indeed, coordinates are tricky to work with. Don't worry tho, soon you get the gist of it.
Re: Adding Digsites
Unread postby Dilophosaurus Rex » Wed, 18th Jul 2007 12:10
Yes, i already figured it out. The digsites that have two sets of coordinates also have two // in front of the top set. I deleted those and now they work fine. I'm still trying to find good coordinates for South America and Europe.
Dilophosaurus Rex
Re: Adding Digsites
Unread postby Triceraptor Rex » Wed, 8th Aug 2007 8:12
I'ne cracked the coordinates! Increase the first number to go further right and decrease the 2nd number to go up.
[quote="Dilophosaurus Rex"]Yes, i already figured it out. The digsites that have two sets of coordinates also have two // in front of the top set. I deleted those and now they work fine. I'm still trying to find good coordinates for South America and Europe.[/quote]
The best coordinates for Europe are (255,90)
I'm just wondering... Can you create your own 'info' page for your digsite because right now, when i click on my digsite and click on the info it goes straight to the 'Fossils, DNA and Amber' page on the DInopedia.
I've just found out that CAmarasaurus is also found in Europe, now my Rocky cliffs digsite in Europe has 2 dinos, compies and camaras!
Reason: I can't believe this... 4 CONSECUTIVE POSTS?!READ THE GODDAMN RULES!
Triceraptor Rex
Mod Tester
User Title: Experiment #762 (55% Raptor/35% Rex/20% Trike)
Re: Adding Digsites
Unread postby Dilophosaurus Rex » Fri, 10th Aug 2007 9:26
I don't really know if you can create new pages in the Dinopedia for this. But it doesn't hurt to try it yourself. Be sure to make backups, though!
Dilophosaurus Rex
