I can not get an avatar D:
Do you have problems reading and it's not your glasses? Does the board suddenly decide to turn on you and glitch to infinity? Well, post your problems and suggestions here!
Unread postby Alpha Allosaurus » Sat, 17th Sep 2011 3:20
I put the link of the avatar, and when I'll see if it worked, it has nothing :argh:
Sorry for the english, I'm Brazilian
Image Image
Alpha Allosaurus
Re: I can not get an avatar D:
Unread postby lexmac0 » Sat, 17th Sep 2011 7:39
The avatar not showing is probably down to one of two things. Firstly, the image you are trying to select may be an incompatible file format, and so may not work as an avatar. I would suggest using eiether a JPEG or a BMP, as these are the safest choices (though I believe GIF and PNG images will probably work as well. If this is not the problem, try taking the image and resizing it to 105x105 using paint/gimp/Photoshop, then reupload it to an image hosting site (photobucket is probably the most sensible option). Now you can try to set your avatar again, specifying the URL as it asks. Also, make sure to add 105x105 to the dimensions, as this may prevent any further errors.
Hope that helps, if you need anything else, feel free to gimme a shout! :amused:
--lexmac0
I don't really JPOG anymore... But I do YouTube! Check it out, if ya have some free time and wanna see some s#!ts and giggles! :D
lexmac0
User Title: SPANJAYtheLION
Unread postby Reprieve » Sat, 17th Sep 2011 10:08
Also make sure you're putting it in the correct box (i.e. link to offsite image).
Reprieve
User Title: flagellum dei
Unread postby Alpha Allosaurus » Sat, 17th Sep 2011 16:10
OK, I'll see if this is my problem ... :)
Image Image
Alpha Allosaurus
Unread postby lexmac0 » Sat, 17th Sep 2011 16:25
any luck then?
lexmac0
Unread postby Alpha Allosaurus » Sat, 17th Sep 2011 16:33
I did it! the problem was the size, thank you :D
Image Image
Alpha Allosaurus
Unread postby lexmac0 » Sat, 17th Sep 2011 16:35
No problaemo! :amused:
lexmac0
Return to Forum & Main Page Assistance
