The GEPv2
Releases of Modding Genesis Expansion Packages!
The GEPv2
Unread postby Eternal_Rocker_Chick » Sun, 3rd Aug 2008 12:08
And now for the release of GEPv2! :)
The GEP stands for Genesis Expansion Project, and is a fan made expansion pack for our beloved JPOG, aka, Jurassic Park: Operation Genesis. This expansion takes most of the modifications found within the original GEP, and adds a whole lot more! The focus is obviously behaviour orientated, and we strive to get as realistic a game experience as possible, by modding several different factors.
This expansion pack does NOT include dinosaur skins. But it does completely change your JPOG experience ^-^
Full Modification List
>Unlimited Park
Increases building limitations, and removes most building restrictions on SiteB. Now updated so you can declare emergencies on SiteB
Author: The Ark
>Viewing Dome Feeder
Changes the Viewing Dome attraction, so that it now ejects dinosaur food like a dispenser
Author: DarkLord
>Tombstone
Adds an unreleased model back into the game for your enjoyment. Although it is only aesthetic, it really creates atmosphere to your Jurassic Park! Can be found via the security menu
Author: Godzilla
>Mission Edits
Various tweaks and changes have been added to the missions to make them more challenging
Authors: Godzilla And DarkLord
>FslHunt Modification
In Operation Genesis Mode, the digsites which were made peroidically available to you depending on your star level have been revised, in an effort to make gameplay more challenging
Author: DarkLord
>Visibility Mod
The dinosaur's visiblity has been tweaked. A sleeping dinosaur isn't noticed as much by another dinosaur, unless it ventures too close.
Author: RaptorX9
>TricDfnd
Triceratop's defensive behaviour has been revised. They no longer go on a complete killing spree, just because they've seen an approaching carnivore. They will now try and 'ward' the attacker away, by roaring and displaying their horns. If the carnivore stay's where it is, the Trike's retreat. If the attacker gets too close, they will attack.
Updated for GEPv2
Author: Eternal_Rocker_Chick and Melea Lord
>Small Prey Dropping
When large carnivores are hungry, they'll swallow small prey whole. However, when they are not hungry, and only want to hunt, they will pick a small target up in their jaws, swing it from side to side and throw it onto the floor, killing it JP style!
>Knockover Modification
Usually, when hunting a medium sized opponent such as a Parasaur, large carnivores would knock it over.... then for some reason walk away waiting for it to get up. Then they would continue chasing.
When have dinosaurs cared about attacking a downed opponent???
Now, there's a chance of a large carnivore knocking an opponent over, then striking it again while it's down, killing it instantly.
Updated for GEPv2: Large carns can now headbutt their prey to the ground and then deliver the final blow. Also, now Cerato and Alberto can deliver a killing blow too!
>Large Carnivore Sniffing
Now, when a large carnivore is scavenging, and finds a dead carcass, it will sniff first, before eating.
>Large Carn Prey and Vehicle Ramming
This modification brings a new attack to your large carnivores. They now can ram opponents with their heads. They will also ram Jeeps.
Author: Apostolos
>Reasearch Tree
A research tree has been implemented into the Operation Genesis mode. Again, this is another effect to make the gameplay more challenging, and also realistic. If you find that you can't research something, there's usually a logical reason why.
Author: DarkLord
>Pachycephalosaurus Duel Health Leech
With this modification, the loser of a Pachy duel will lose health
>TRex Upgrade, Spino Downgrade
The TRex has now taken it's rightful place at the top of the foodchain!
Author: DarkLord
>Constant ini
There have been multiple tweaks to the constant.ini file, such as starting money, and terrain presets
Author: DarkLord
>Pricing
The prices of nearly everything in Operation Genesis mode have been tweaked to be more realistic, while at the same time increasing game difficulty. If you're loading a saved park with this pack, make sure you reduce your pricing, or your visitors will start to leave
Author: DarkLord
>Raptor/Rex DeathDuel
One of the most popular modifications from the previous CEP packs, this modification makes a return. The actual mod adds a whole new set of interactions between your raptors, and your TRex. Rather than the raptors just running away, they will now engage in a 'duel' with the Rex.
When it approaches, they will try and warn the Rex away by barking. If it gets too close to a pack of raptors, they will attack it!
In this version, a lot of bugs have been fixed. The Rex also has a new attack. Rather than always just picking up the raptors in it's mouth, it now has the chance to bite them on the floor, crushing them. However, this attack does not kill them, although they wil be extremely hurt. Injured raptors will not engage in duels, and will always flee.
Note: If you cannot get this duel to work, make sure your raptors have actually formed a pack. When you first bring them out of the hatchery, they will not pack until they've made their first kill.
>Raptor Jeep Chase
Rather than just fleeing from a landcruiser, raptors will now interact with it. They will chase it, and bark at it, then run away. Basically, it's their new toy!
Note: Raptors will never actually harm the landcruiser in any way
>Hill Climbing Mod
Different dinosaurs can now climb further up hills than others. An easy escape idea for a small herbivore
Author: Screaming_Eagle
>Large Carn and Raptor Fence
This modification makes raptors and large carnivores a lot harder to keep! They will now attack fences periodically, testing them for weaknessess. They don't like being caged up!
With this modification, make sure you test your fences regularly, otherwise you could have a major escape epidemic on your hands. Those security cameras and sentry turrets suddenly seem like a good idea, don't they?
>Dinosaur Sleeping Modification
Now your dinosaurs will be a lot more wary about where they sleep. They will now seek the cover of trees before they lie down. Sleeping out in the open is very risky, and they will only do it if they have no other choice, or are so tired, they literally fall asleep where they are standing.
>Allosaur Territory Duels
The Allosaurs are now like any other large carnivore. They are territorial, and will engage in disputes
>Ambush Modification
One of the larger modifications, this will add a whole new way for your large carnivores to hunt prey. If there are tree's nearby some unsuspecting prey, there's a chance that your large carnivore will lie down amongst them... waiting patiently for prey to wander close enough. If it does, the large carnivore will spring from it's hiding place, and attack it's prey.
>Terrain Modifications
Completely changes your terrain to give a more jungle-like theme. The foliage is thicker and the textures and colours refined. The water colour on lower terrain levels has also been changed. No more illuminous bright blue water
>Sneaky Modification
Large carnivores are now cleverer than before when seeking prey. If there are trees nearby, they will use them as cover when approaching prey, hiding them from view
Author: Melea Lord
>Dead Prey Swallow
Instead of just pulling meat of out small dead carcasses, large carnivores will now grab them off the floor and swallow them whole
>Tracking
Large Carnivores will now sniff the air at different intervals while hunting, to give the impression of tracking
>Raptor Stress
Raptors will no longer rampage easily. They are supposed to be intelligent creatures, and it made no sense for them to go crazy all the time. However, when they do rampage, they are now a lot more deadly.
>People Grab
Visitors will no longer just stand still, waiting for a large carnivore to sniff them, and then eat them. They will now flee immediatly, and the large carnivores will have to chase them down
>Alberto Upgrade
The Alberto has been moved up the foodchain. All other small carnivores will now be scared of it
>Raptor Sneaky Modification
Same as the sneaky modification, but now with raptors too
Author: Melea Lord
>Large Carn Warn
Large Carnivores are very territorial, and they now have a chance of geting into fights over food. If a large carnivore has killed or found a a meal, it will check it's surroundings. If there's something it doesn't like, or if it wants to be left in peace, it will roar, trying to scare away anything that's nearby. If a dinosaur gets too close, there's a chance that the large carnivore might even chase it off, before returning to it's food.
Also, this modification makes large carnivores picky about their food... that is, if they're not starving or injured. A large carn might be about to eat a Parasaur... but suddenly see's an Edmonto wandering past. There's a large chance the large carnivore might abandon it's food, choosing instead to hunt down and kill the edmonto!
Large Carnivores need their fun too!
Updated for GEPv2: Allo's, Carchar's and Acro's will now also take part in this activity!
>Herb Groups
Herbivores used to scatter about the island. They really had no preference as to who they were with as long as it was a herbivore. Yes, they used to pack, but different packs used to mingle together, and they probably had nothing to do with eachother in real life. Now, herbivores tend to stick with their own little 'friend' groups.
>Ultra Social
Herbivores will now lie down and rest while socialising, calling to other members of their herd. This has also been implemented into some large carnivores.
Author: Melea Lord
>Dino Speed Variation
Dinosaurs will walk and run during play at different speeds for more variety.
Author: Melea Lord
>Sneeze Mod
All dinosaurs now have the ability to sneeze during idle mode.
>Raptor DeathDuel
Raptors will randomly duel with eachother. Rarely, this will result in a fight to the death.
During idle mode, there's a chance that one raptor will target another in it's pack and pounce on it. Think of it as a play fight. Like young predators such as lions do in the wild. It's just praticing their hunting abilities, and it will hardly hurt the attacked raptor.
The raptor who attacked will then back away from the fallen raptor, waiting for it to get up so they face eachother. The attacker will then bark playfully at it's opponent. The opponent, will give a disgruntled hiss in response, and then they will both run away from eachother, and then the pack's activities will continue as normal. No hard feelings.
However.... sometimes.... it can be taken too far....
Rather than run away after the final hiss, both raptors will hiss together at eachother. This means, that they mean business. Both are quite annoyed at eachother. It will then turn deadly. One of them will leap onto the other, this time either injuring it, or actually killing it.
>Beat SW Migration
Creates random movement in many files to prevent migration to the South West of the map
Author: Melea Lord
>Hill Mod
Activates an extra terrain tool which creates small flat hills. An unused feature not put into the final game
>Seek Redone
While attacking/hunting, dinosaurs are forced to face their target, making a much more effective attack.
Author: Melea Lord
>Muster Special Attack
The original deathduel attack sequences have now been added to the muster file, which basically means they have an increased chance of occuring.
>Raptor Age Restrictions and Experience Recording
Younger Raptors will not hunt as pack. They learn to hunt as a pack with age.
Author: Melea Lord
>Stalking Modification
Large Carnivores will now stalk their prey.
Basically, if there are trees nearby and a large carn is quite far away from it's target, it will seek towards the trees, face the prey, and stand still. It will then stalk the prey, slowly moving forward to get closer. When it gets too close or prey has seen it, it will attack.
>Flee Improved
Fleeing dinosaurs will now constantly reacquire the nearest threat and flee from it, rather than just acquiring one threat and running straight from it, into another. Also, sight values have been increased so now prey can spot predators from further away.
>Dilo Paralysis
Dilophosaurus are now quite dangerous. Now, when they attack prey, the spit slowly paralysizes the opponent, causing it to collapse and fall into comatose. The Dilo can then either decide to finish it off or leave it to die.
Author: Melea Lord
>Raptor Join Request
Raptors will now 'request' a place in a pack. They will run upto a member of the pack, and bark at it. If the opponent ignores it, for example, if it is hunting, then the joinee will chase the raptor barking until it gives the raptor attention. Once it has it's attention, it will bark again, and the other raptor will hiss in response.
Author: Eternal_rocker_Chick
>Sound Tweaks
Minor tweaks to the ambient sounds. They are now much louder, and really help absorb you in the feel of a jungle.
>New Terrain Edits
The grass has now been replaced with dark lush ferns. All the sky textures for high terrain have also been replaced with higher quality ones. The medium terrain texture has also been replaced with a highly detailed one.
>Hunger Thought
When carnivores are scared, they would ignore all other needs and just try to escape the aggressor until they died. Now, they actually think for themselves. If a T-Rex approaches a Trike, and it's not hungry at all, it will most likely flee. It would have nothing to gain from the fight. However, if it was hungry, it will now hunt that Trike down!
This works for all Carnivores, including Raptors and Dilo's.
>Attack Variation for Large Carns
Large carns can now knock small prey to the ground and then grab it in their mouth simultanously. They can also ram medium prey, causing it health damage and to recoil slightly. They can then finish it off with a bite if it's close enough, otherwise the prey can escape.
Author: Melea Lord
>Large Carn Territory Duel Revamp
Very varied duel behaviour, with different outcomes
>Speed Mod
Dinosaur speeds have been made more accurate according to sources and modern day animals.
Author: Melea Lord
>Improved Raptor Flee
Now if raptors are faced with a large threat in the shape of a dinosaur and are enclosed in with fences, they will attack the fences to try and escape.
>Shading Modification
Improves the visual shading element of the game. Improves realism. Medium terrain values suggested by Triceraptor Rex.
>Predator Need Decreased
Predator Need of all carnivores has been decreased slightly
>Dino Scared Needs
Now when confronted with fear, carnivores and herbivores will take into account their thirst. If the threat is moderately far away, a source of water is near and they are thirsty, they will quickly stop to take a drink. If the threat gets too close, they will stop drinking annd continue fleeing. This gives the attacker an oppurtunity to sneak up on the prey. This also greatly reduces the amount of malnutrition releated deaths. Herbivores will also take into consideration their hunger value
>Wake Up Roar
A large carn shall sometimes rise from it's slumber to scare away nearby dinosaurs. They can do the same while drinking and eating. This can lead to territory disputes between large carnivores of any variation.
>Mist Effects
Another graphical enhancement. Adds a 'mist' effect to the terrain in the distance.
>Sleep With Friends
Herds will now seek out each other to sleep together.
Author: Melea Lord
>Last Attempt Mod
After prey has been dealt a final blow and is knocked to the ground, it now has a chance that it will try to get back to it's feet, but fail and fall back down again.
This release also features a few Save Games. These are:
>Tropical Paradise
A scenic, natural environment, for your dinosaurs to live out their life
>Ruined Beauty (Site B)
A mountainous area full of rivers and lakes. Old fencing still exists.
>Jurassic Park (OpGen)
A beautiful interpretation of Jurassic Park
>Volcano Plains (Site B)
A large island with a ring of mountains, creating jungle centre, with wide plains surrounding.
3567
Ze Download!!
<--link not working, donwload the combined pack and install the v2-->
This is a RAR file. Use WinRar to extract the installer exe. Then all you have to do is double click the Installer and follow the instructions.
Edit: Click here for the combined pack of the Genesis Expansion Project Version 1 and Version 2
Reason: Updated with a new download link.
User Title: Talking Duck
Re: The GEPV2
Unread postby raptorkid123 » Sun, 3rd Aug 2008 12:10
Wooooo i love you Modding Genesis and G.E.P
raptorkid123
User Title: Velociraptor
Re: The GEPV2
Unread postby SusannaNO2 » Sun, 3rd Aug 2008 12:16
Oh man, i really love you guys! :x3: First, i almost got dissapointed when i realized that my time is one hour before yours in England.. But now, im sooo happy! :amused:
SusannaNO2
User Title: RECKONER
Re: The GEPv2
Unread postby Veloraptor » Sun, 3rd Aug 2008 12:38
will a skin like my "Red Lightning" Raptor be overwritten?
if i write something wrong, send me a message
Veloraptor
Re: The GEPv2
Unread postby Gravekeeper67 » Sun, 3rd Aug 2008 12:49
Veloraptor wrote:will a skin like my "Red Lightning" Raptor be overwritten?
There are no skins in the pack so what would overwrite it.
I am making a series using JPOG. Episode 2 is up.
World of Dinosaurs Episode 1
http://www.youtube.com/watch?v=Nq9H3ynbfJs
World of Dinosaurs Episode 2
http://www.youtube.com/watch?v=smrUVdYcdJY
Gravekeeper67
User Title: The keeper of your grave.
Re: The GEPv2
Unread postby raptorkid123 » Sun, 3rd Aug 2008 12:50
Wow that shading mod is cool The GEPv2 rocks although i think you shouldve included the night mod :)
raptorkid123
Re: The GEPv2
Unread postby Eternal_Rocker_Chick » Sun, 3rd Aug 2008 12:59
Wait until it gets to stormy weather for high terrain quality :P
Re: The GEPv2
Unread postby ravenclawstefan » Sun, 3rd Aug 2008 13:00
Well... I waited... hours... days... and it all comes down to this... :shock:
... YEAHHH!!!! :iria:
*Downloads*
Some say the glass is half full, some say the glass is half empty. I say “Are you gonna drink that?”
ravenclawstefan
Friendly Herbivore
Friendly Herbivore
Re: The GEPv2
Unread postby Sammyfishing » Sun, 3rd Aug 2008 13:11
wow u guys are great :iria:
Sammyfishing
Re: The GEPv2
Unread postby raptorkid123 » Sun, 3rd Aug 2008 13:13
Eternal_Rocker_Chick wrote:Wait until it gets to stormy weather for high terrain quality :P
i thourght it was light rain anyway you little rascul come here :glomp: i love you and your work
raptorkid123
Re: The GEPv2
Unread postby Eternal_Rocker_Chick » Sun, 3rd Aug 2008 13:15
Aww, lol :glomp:
Yeah, it was. So, we've combined the dark feel with the high quality stormy weather. Basically, for stormy weather, it'll be quite dark, but only on high terrain quality.
Re: The GEPv2
Unread postby SusannaNO2 » Sun, 3rd Aug 2008 13:17
Eternal_Rocker_Chick wrote:Aww, lol :glomp:
Yeah, i have high terrain quality! :P
Heh, i love the brachiosaur's sneeze animation! It's like; "Ahhhhh-Hummphh" xD
SusannaNO2
Re: The GEPv2
Unread postby raptorkid123 » Sun, 3rd Aug 2008 13:18
So on my Terrain quality must be on high ill check now plus you must have a high graphics card? For high terrain if so i need a new graphics card. The highest i will go is medium :sweatdrop:
raptorkid123
Re: The GEPv2
Unread postby Eternal_Rocker_Chick » Sun, 3rd Aug 2008 13:19
Yeah. For the full graphical impact the GEPv2 offers, you'll need to have reflective water on, and terrain quality on high.
However, for those of you on medium terrain quality without reflective water. What do you think of the ground texture? I was a bit iffy with it. But decided to use it in the end
Re: The GEPv2
Unread postby raptorkid123 » Sun, 3rd Aug 2008 13:21
Eternal_Rocker_Chick wrote:Yeah. For the full graphical impact the GEPv2 offers, you'll need to have reflective water on, and terrain quality on high.
Its cool but like in the trailor its better because you have a high graphics card my birthday is next sunday so ill ask for one :)
raptorkid123
Return to Genesis Expansion Project
