The GEP
Releases of Modding Genesis Expansion Packages!
Re: The GEP
Unread postby borna » Mon, 29th Dec 2008 12:00
it doesnt work.....it says that file is broken.......please help.....!!!!!!!!!!!! :sweatdrop:
i have gepv2 version......do i need to have gepv1.01 or its the same with some new stuff!!!!!!!!
when i install gepv2 it doesnt work......???????????????
do i need to have gepv1.01......????????????
Reason: Double Post
borna
Re: The GEP
Unread postby Baryonyx » Mon, 29th Dec 2008 13:36
borna wrote:it doesnt work.....it says that file is broken.......please help.....!!!!!!!!!!!! :sweatdrop:
Don't add too many exclamation/question marks.It is annoying.GEP v2 is the new version including most of the things from the previous GEP/CEP packs.You only need to install it once.I have no idea why it's broken,try redownloading.
Baryonyx
Feisty Herbivore
Feisty Herbivore
User Title: What now?
Re: The GEP
Unread postby borna » Mon, 29th Dec 2008 13:58
thanks i will try again :)
borna
Re: The GEP
Unread postby hamzah12 » Tue, 30th Dec 2008 23:41
hmmm.... have you try to download to the jpog folder? if you have try it, then it should work
hamzah12
Re: The GEP
Unread postby leevancleef » Fri, 23rd Jan 2009 3:54
I am having the same problem. The file downloads fine, but when I go to unzip it says: "The file is either in unknown format or damaged".
leevancleef
Re: The GEP
Unread postby Baryonyx » Fri, 23rd Jan 2009 9:32
leevancleef wrote:I am having the same problem. The file downloads fine, but when I go to unzip it says: "The file is either in unknown format or damaged".
May i suggest you post in the gep v2 topic?But to answer your question,you should try redownloading.When i downloaded it nothing wrong happened.The file worked perfectly.
Baryonyx
Feisty Herbivore
Feisty Herbivore
Re: The GEP
Unread postby leevancleef » Sat, 24th Jan 2009 2:35
Thank you, the GEPv2 works like a charm.
leevancleef
Re: The GEP
Unread postby jacobmcnew » Sat, 24th Jan 2009 18:50
i installed but it keeps not working even when i paist it into jpog data DX
jacobmcnew
Re: The GEP
Unread postby Docszoo » Sun, 25th Jan 2009 1:07
Please read a few posts above you. Download the GEPv2.
-Andrew
Docszoo
User Title: Docszoo
Re: The GEP
Unread postby Clonetrooper101 » Wed, 11th Mar 2009 4:16
The GEP might not be as good as the GEPv2 but I think its a very good pack.I give it a thumbs up. :approve: But I don't like the injured walk modification.
Clonetrooper101
User Title: A member of the 501st Legion
Re: The GEP
Unread postby PWOKristy » Fri, 24th Apr 2009 18:19
Hello,
I have a problem. When I downloaded it with Win Rar I get this error message "C:\Documents and Settings\Local Settings\Temporary Internet Files\Content.IE5\9LDP7ZUE\GEPv1.01[1].zip: Unexpected end of archive". When I try to open it any ways it gives me this "The archive is either in unknown format or damaged". And "Can not execute". What's wrong?? I'd like a different site to download the 1st Genesis Expansion Project from.
Thank you!
Regards,
Kristy.
I have a Pleo (a robotic, sauropod dinosaur)!
PWOKristy
Re: The GEP
Unread postby maximusthedark » Tue, 14th Jul 2009 3:12
To announce that there must be no criticism of the President, or that we are to stand by the President, right or wrong, is not only unpatriotic and servile, but is morally treasonable… — Theodore Roosevelt
maximusthedark
User Title: Catervarii, mediocre artist...
Re: The GEP
Unread postby Niko » Sat, 18th Jul 2009 21:34
A Very nice Pack!
Niko
Re: The GEP
Unread postby Galox » Thu, 27th Aug 2009 13:05
After I got this pack, some weird thigs started happening :shock:
After a Rex-Spino Death Duel, they sort of get shot away from each other. The loser walks off for a bit, then suddenly dies.
The other one is that Raptors "Dig" into the ground. I was watching my Raptors hunting a Para, then suddenlky, there heads went into the ground and left there tails sticking out, swinging wildly. Thank goodness these only happened once!!
Galox
Re: The GEP
Unread postby jpfanbunce » Mon, 7th Sep 2009 18:20
Docszoo wrote:Please read a few posts above you. Download the GEPv2.
Hey how do you get to the home page?
jpfanbunce
Return to Genesis Expansion Project
