Easy 5-Star Park
Useful tips for making the perfect slaught-i mean-theme park.
Easy 5-Star Park
Unread postby DinoDude65 » Mon, 28th Dec 2009 3:07
This method always gets me high ratings very, very quickly.
First of all, you need to have the Hill option activated. You can do this by downloading the GEP v2, or you can go into the BldMenu.ini and underneath
command = Mountain;
copy that code and replace "Mountain" with "Hill". Once that's ready, make sure that your Land Cruiser can go up the hills, by checking your Constant.ini and going down to the code
JeepMaxAltitude =  8.5;
and changing 8.5 to something bigger than 20. Now you can make elevated tour roads :D
Then when you go to make your park, delete a section of fence and build your hill going right by it. Have the Safari Adventure tour drive by each enclosure to give an original Jurassic Park effect. If you get enough people to go on the tour, your star rating should sky-rocket.
"The mighty tyrannosaur arose late in dinosaur history..."
DinoDude65
Re: Easy 5-Star Park
Unread postby jpdude52601 » Fri, 22nd Jan 2010 13:08
uh......i have ps2. :guns: :tear:
jpdude52601
Unread postby Reprieve » Fri, 22nd Jan 2010 18:31
All of these mods won't work on the PS2 version.
If you speak to Sarge though, I think he's working on something for the PS2
Reprieve
User Title: flagellum dei
Unread postby Velociraptor-E21 » Sat, 20th Feb 2010 21:13
jpdude52601 wrote:uh......i have ps2. :guns: :tear:
ok... I have both an i can easily say that random stuff that happens only on MODDED pc versions can happen on PS2. and yes i know this is pointlessly reviving an old topic...I had an urge to post! :guns:
Why try to live, when you know your gonna die?
We were created to live, yet we destroy.
The end is not the end, but a new begining.
Velociraptor-E21
User Title: A Mechanized Velociraptor, trained to kill
Return to Strategy
Users browsing this forum: Bing [Bot] and 1 guest
